benflugel
- Jun 8, 2023
- Spalding
- MG4 (2022-2025)
I went from R46 to R63. When I first got the car in June 2023 it had R30.These fixes seem to be consistent.
But can you tell me what version you had before the update ? And did you perhaps get intermediate updates as well? I'm asking this because LKA become a lot milder with the May 2024 updates.
More: is the charge % ISSUE fixed?
Do you miss the pull down menus (a/c and lka) when using AA/AC?
I do miss the pull down AC controls which now don't work whilst in Android Auto. But it's not a big deal at all. Steering wheel shortcut button deals with that
The only other update I've had was back in May 2024 when I had a new CCS unit fitted when it stopped AC charging - the update which changed the ACC control from 5mph increments to 1mph. I noticed no change in ACC or LKA performance from that.
Fiest impressions are much better but need more trips to really tell.
Another couple of journeys completed. Around 40 miles now in total. I would go as far to say it drives like a different car. If you were used to turning off LKA for each drive, and used the ACC frequently, I would say it's like driving a different car.
It may be because I have skipped a fair few versions of software and therefore have a bigger gap in experience than others, but it is quite noticeably different.
ACC is more grown up - it doesn't jolt, judder, speed up and slow down - it's much smoother and keeps a consistent gap with the car front rather than speeding up and slowing down. I have found the setting to control the distance has changed. I now use the biggest gap option. I always used the middle setting before but this felt a lot closer post software update.
LKA has really mellowed. Pot hole laden single track A road required some movement towards the white lines. This would have thrown me back to the centre quite aggressively previously. This time, I either get a beep only, or a beep with a very light nudge back to the centre. Not shocking or scary, just as you'd expect. I've also noticed that the country roads I have to use to get to my main A roads are no longer recognised by LKA at all. It stays disabled and doesn't recognise the lines. Which is much better.
Oh, and I now set the AC at 21 and can leave it. No more sudden bursts of cold at 24, requiring a move to 25. Which more often than not resulted in bursts of heat. Always a jump between those two temps for me. 21 sorted it all out and kept a consistent temp.
