Yes, I noticed the size difference, but it would only be used in an emergency so would not be on for long. Dont trust the blow up kit provided which is why I have a space saver. I will move that over to the face lift (cant't we find a better name!) next week when it arrives (hopefuly!).It fits but it is technically the wrong size the rolling circumference is smaller as MK2 wheels are bigger and will probably set off abs probably OK in a emergency?
How about the Botox as a new name?Yes, I noticed the size difference, but it would only be used in an emergency so would not be on for long. Dont trust the blow up kit provided which is why I have a space saver. I will move that over to the face lift (cant't we find a better name!) next week when it arrives (hopefuly!).
To be honest a plug kit is a lot easier than changing the wheel over even if you use them screw in onesYes, I noticed the size difference, but it would only be used in an emergency so would not be on for long. Dont trust the blow up kit provided which is why I have a space saver. I will move that over to the face lift (cant't we find a better name!) next week when it arrives (hopefuly!).
My brother used one a few years ago, it didn't work and made a right mess of the tyre. I have heard of a couple of similar incidents with them since. Having said that I have also heard of succesful use so it's luck of the draw and maybe also correct use. I do still carry the inflation kit but I also like a space saver. Sort of belt and braces syndrome I suppose.To be honest a plug kit is a lot easier than changing the wheel over even if you use them screw in ones
Errrrmm..........................Perhaps not, but a good try.How about the Botox as a new name?
