Deleted member 14627
- Sep 17, 2023
Can I fast charge the battery on my HS hybrid at a charging point? I have the correct type 2charging lead? Or do I have to leave it there for 5 hours to fully charge?
Hi, many thanks. I’m new to these hybrid cars so forgive my ignorance but what is a CCS DC connection and do I need to buy another cable or are they on the charging units?Hi, Fast charging uses the type2 AC cable which can take a few hours. Rapid Charging uses the CCS DC connection and will be done in 30 minutes.
CCS is the type of large fixed charging gun that you will find on a rapid charging unit.Hi, many thanks. I’m new to these hybrid cars so forgive my ignorance but what is a CCS DC connection and do I need to buy another cable or are they on the charging units?
Yes, if I use the granny charger I get around 1.8-2 kW per hour, so it would take around 30 hours to charge my MG4 from 0 to 100%, on a wall charger I average just over 6kW per hour so would take 10 hours to achieve the same. But the HS tops out at 3.6 kW per hour, I believe, so the it would halve the time to fully charge over the granny, as opposed to 1/3 for the MG4.Thanks, but does it charge quicker on a wall charger?
I understand your quandary, our solar panels put out 3.7 kW at best so a wall charger will use the grid to make up the difference, unless I tell the car to limit the ac current. So I just use the granny charger for longer, if I need the get the car charged quickly I'm 5 miles from some DC chargers and £1k buys quite a few kWh even at the expensive rate of 75p per kWh. Of course this may change come the winter and I'll wish I had a wall charger.Right now I'm charging on the granny charger and its around 1800w or 1.8 kw. So if the wall charger was at 3.6kw - double the granny charger it would be a good improvement, BUT is it worth spending $1k plus install to get it ..hmmm.
Our solar panels can put out 5kw and we also have a tesla powerwall battery and free power from 9pm to midnight 7 days. So I have a few options,the 3 hrs free power is enough to charge the car with the granny charger if it has more than 50% battery and if needed I can start the charge once the sun goes down from the powerwall battery as it will fill up again at 9pmI understand your quandary, our solar panels put out 3.7 kW at best so a wall charger will use the grid to make up the difference, unless I tell the car to limit the ac current. So I just use the granny charger for longer, if I need the get the car charged quickly I'm 5 miles from some DC chargers and £1k buys quite a few kWh even at the expensive rate of 75p per kWh. Of course this may change come the winter and I'll wish I had a wall charger.
As others have said a wall box will be faster than the supplied Granny lead.Thanks, but does it charge quicker on a wall charger?
Thanks for the advice, Yes I think I will go for the 7kw wallbox. Just have to find one that lets me schedule off/on times inthe appAs others have said a wall box will be faster than the supplied Granny lead.
Some companies will offer you a 3.5 Kw wall box if you have PHEV as the onboard charger can only handle 3.5 Kw’s.
But I would strongly recommend that you go for a wall box that is 7.0Kw’s instead.
The extra cost to me was only about £30 at the time of my install.
We had a VW PHEV at the time and of course having a 7kw unit was over kill.
But consider if you replace your PHEV in the future for a full BEV your 3.4 Kw wall box will still only charge at 3.5 kw’s !.
So future proof yourself and go for the 7.0Kw wall box !.
Assuming your home electrical system can accommodate it of course.
Another advantage of having a wall box and a Granny unit, is that you now have a second means of charging your car, should one of units develops a fault.
@Cafeg thanks for the image, so is this an app that connects to a walll charger? I’m keen to find a way to track usage so I can claim through work.Right now I'm charging on the granny charger and its around 1800w or 1.8 kw. So if the wall charger was at 3.6kw - double the granny charger it would be a good improvement, BUT is it worth spending $1k plus install to get it ..hmmm.
The other point is how would I communicate with it as the HS phev doesnt work with Mg ismart app ( its a pity MG cant fix that )
