Fault with usb ports
OnlyEV
Cornwall
Had my new 21 reg mg5 ev delivered yesterday, went to set up my android auto but none of the usb ports work, they won't charge any phone, I have tried 5 different phones and 7 different cables, anyone else had this problem or do I need to return the car already.
Might be stating the obvious here, but was the car turned on ?
I don’t think that it’s a known issue. You have done the obvious and tried different cables with different devices. It sounds like the usb ports may not be connected up - which could be an uninstalled fuse for example. It should be a while you wait fix by the dealer 🙂
Where is the fuse box located
There's a fuse box on the driver side. If you open the door, then pry off the panel using something plastic you can get to the fuses
