KH11
- Apr 9, 2023
- Location
- Wakefield
- MG4 Trophy LR
Done my first Rapid Charge this afternoon. Charged up from 19% to 80% at MFG/Ev Power nearby. I used the Electroverse card as it was showing that you got it at 75p per KW instead of 79p.
I wanted to make sure that the Electroverse card actually worked as I had tried it at IONITY at Skeleton Lakes a couple of months ago and it didn’t work.
Well it worked no problem just flashed the card against the reader and it then said select cable which I did and plugged in the car and off it went charging. Was also pleased with the charge rate as well as it peaked at just over 137kw and it took 24 minutes to go from 19% to 80%. When it reached 80% the charger showed it had stopped charging and it the car bonged and I was able to take the cable out and place back in the charger point.
Well impressed
Well impressed
