PercyMinder
Since new my MG4 SR has had a number of issues and over its first year of ownership has been to dealers 5 times to be fixed but the issues noted below are still occurring. I would value any input about whether the issues I am seeing are unique, or if owners are aware of solutions.
Perpetual issue:
1] On switching the car from Normal to Sport on the central screen with in a few minutes the setting jumps to ‘Snow’ (- although I believe the car is in Sport mode).
Occasional issues:
2] Fails to ‘see’ the key and refuses to go into drive - the only solution has been to get out the car, lock it and then start again.
3] Reduced regen braking warning given above 95% SOC does not always display.
4] Reduced regen braking warning appears at SOC below 95%. (Although braking not affected & from memory the record low is 73%).
5] Energy use ‘green bar’ has appeared as orange.
6] Android Auto on the central screen - I have many of the issues noted by other contributors - in addition (?) if I switch off ‘maps’ to alter central screen settings and the maps are off for more than a few seconds the phone link is most often lost. I also have problems that the associated ‘star’ button and ‘speech’ buttons on the steering wheel can refuse to work.
7] Quite often the message ‘please plug in the charge connector’ appears at a high SOC e.g. 95% - although I’ve not got this message when its SOC has been below 40%.
8] (This has only happened when waiting at traffic lights). Sitting in drive & handbrake on. Go to accelerate away and car refuses to move and tells me to ‘fasten seatbelt’…… The only solution I found was to put the car into Park then start again.
(The one issue that does appear to have gone away is that the ‘car’ switched off the TSR function on more than one occasion - have I just tempted fate?).
Perpetual issue:
Occasional issues:
