The only time I used a Granny was when we got the MG4 and before our Ohme Home Pro was installed. I have an MK Masterseal outside on the drive that I ran as a 16A radial using a length of 1.5 butyl heat resistant cable that I had left over from installing immersion heaters. I installed it as a GP outdoor socket for garden tools, lawnmower etc, well before we decided to get an EV.
We used it a lot in the early days and I did check the plug and socket every time, but didn't notice any issues.
And a big dollop of luck.
I know you're cynical. I'm just answering Coulomb's query about British Standards.
Hager make a 13A EV charging specific socket.
Chop off your potentially dodgy plug and replace it with an MK646 plug. I should have mentioned these earlier. They are very robust and a reliable plug to use at higher currents.
I don't know about these days, but back in the day, organisations like the PO (and then BT), the BBC, Granada and even the MoD, just to name a few, used to swear by them and all had their marks moulded or printed on the tops of the plugs in place of the MK logo.
Do check though before you chop off the plug that it hasn't hot a temperature sensor built in.
The lead is normally quite large and will say something like...3G X 2.5 + 2G X1.5 printed or moulded into the cable. This indicates 5 wires, the 2.5 mm sq being the main power conductors and the 1.5mm sq are the two wires for the sensor.
