djr
Hi all,
My granny charger seems to be working 'on and off'. Works for a bit, the stops, then I reset, works for a bit more, ... and so on.
As we are now in Winter and I don't do that much driving (only local) in comparison to Summer, so I've been putting 30-40 miles on the battery with the granny charger, which has been fine until now. I had the 3 year service completed last week, so I'm not sure if that has caused the problem.
When I plug the charger in it starts off OK and puts about 5 miles on, but then charging stops. There are 3 lights on the charger: 1) Power, 2) Charging and 3) Fault. When I start off the Power and Charging lights are permanently illuminated and charging is OK for a bit. Then the Power and Charging lights start flashing and the charging process stops. The Fault light doesn't come on at all.
The badge on this car has never lit up when charging. I did mention it during the recent service, but the message didn't travel through from receptionist to workshop. Both rapid and granny charging have been perfectly fine until now. I haven't tried rapid charging yet, but will do so in the next week.
Any ideas? The electric socket that I plug into is perfectly fine. It’s in the garage and I’m not using an extension lead.
