- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4
Actually three times today. (Yes, it's brass monkeys here.) First time of asking, not a hiccup.
Which, afaik, only works when the infotainment system is running. So as much use as a....There is an option to connect your car to your Wifi, if the local signal is poor.
Well that messes that one up then !!Which, afaik, only works when the infotainment system is running. So as much use as a....
I fired it up yesterday, and a bit of heated seat too, and it was gloriousIt's a very frosty morning and I decided to try out the remote heating option using the iSmart iOS appl. But after several attempts I have given up. None of the options work, seat heating, windscreen heating, A/C control. I've tried remotely locking/unlocking the car but nothing fixes it.
Instead, all I get is this rather bafflingly mistranslated error message.
Any ideas? Have any of you managed to get this feature to work? Doesn’t seem there’s a whole lot of point in having a remote control that you have to actually go outside and start the car before you can use it!!
Aha! It’s working today!
Now.. if only you could switch on steering wheel heating remotely too!
As expected, mine worked ok this morning, just as well because it was -2 degrees, and well frosted up, so it took a couple of minutes more than it's allotted 10 minutes, but all good.I expect to try mine tomorrow for the first time this year, but it worked perfectly last year.
Ah, I have never used the Wifi, that's silly.Which, afaik, only works when the infotainment system is running. So as much use as a....
FWIW, you can actually run it twice before it prevents you from using it again (to preserve the 12v), so you can get 20 minutes of cooling (or heating) out of it.I have used it a few times when at college and the car is hot. Just wake the car up and turn on the A/C so it's cool(er) when I get back. It only turns on for 10min at a time. When it's about 38 degrees outside then it would probably closer to 50 inside. It is down to about 28-30 when I get to the car.
I more often forget and then I am annoyed for forgetting.
