Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4
I don't use the immersion heater much, maybe only for a boost in winter. I use the oil central heating for the water.
Ooof, shouldnt have said that, you will have que's of heat pump salesmen round the front.I don't use the immersion heater much, maybe only for a boost in winter. I use the oil central heating for the water.
I don't know. Last year I made several enquiries to companies I found on Google and only one responded. I've decided to go with the Tepeo Zero Emmission Boiler instead.Ooof, shouldnt have said that, you will have que's of heat pump salesmen round the front.
Allegedly they are over 300% ifficientQueues. Just saying.
I saw a heat pump yesterday, in a new house that was part of an open gardens exhibition. Looked like an enormous air-conditioning unit. I would have thought it would eat electricity.
Yes, heat pumps produce more heat energy than they use. However, they do draw a considerable amount of electricity in doing that, so a house without solar/battery can see a significant bill increase for electricity, but typically this is dramatically outweighed by the elimination of gas / oil / electric heating that was used before.Allegedly they are over 300% ifficient. That is they give out 3 times the heating energy that they use in electricity.
I suppose it depends on how you view energy used, a typical gas boiler is 20 to 30 kW, even the biggest of the heatpumps only consumes a maximum of 4.8 kW when they're working flat out which isn't often in most installation, a lot less than the 7kW wallboxes that we use!Yes, heat pumps produce more heat energy than they use. However, they do draw a considerable amount of electricity in doing that, so a house without solar/battery can see a significant bill increase for electricity, but typically this is dramatically outweighed by the elimination of gas / oil / electric heating that was used before.
they work in Scandinavia fine although their houses are invariably better insulated than ours
I was going to say that, but on reading the article he is talking about problems with heat pumps reaching the recommended 60C for hot water and the costs of installs (which I think includes the insulation costs).they work in Scandinavia fine although their houses are invariably better insulated than ours
nottenergy.com
Mmmmm, actually it lasted over a week and was a right pain in the derrière trying to get anywhere. Many Cornish folks are not the best drivers in the snow and ice, not seemingly to understand "don't use the brakes"! The centre of Newlyn ( a small fishing port) on a snowy afternoon in mid December, was sight to behold, with gridlocked cars pointing in all sorts of directions ?. It took me all of two hours to get home (just 3 miles), due to several low speed collisions, cars positioned 90 degrees across the road, or abandoned by the roadside at all sorts of angles. Anyone from your part of the world or Scandinavia would have held their head in their hands in frustration. ?A mere dusting. Which no doubt lasted for a few hours!
