Help with High Voltage Wiring on MG5 Exclusive Slam Panel Replacement
Aras
poole
Hi everyone,
I recently bought a lightly damaged MG5 Exclusive with a Cat S rating. The slam panel is cracked, and I’m planning to replace it myself. However, I’m running into an issue with the high voltage wiring that runs through the top of the slam panel. I’m not sure how to disconnect the two wires that don’t have plugs without taking apart the charging unit.
Has anyone dealt with this before or could offer advice on how to proceed?
Any help would be greatly appreciated!
Thanks in advance!
Never done this on an MG5 but it would be unusual for the HV cables to be permanently attached to the charge port, there must be a way to disconnect them up front.
I can definitely disconnect them by opening the charging unit but can I open it? Is it glued?
They sell this hv wires and they look that :
Can I take this panel off?
Great find, @Alb do you have the same information for the charge port side?
