A simple question, a very complicated one to answer!
Key hits on range are: -
1 - Cold weather, especially below 10C. Winter range can be 3/4 of summer or less!
2 - Over 100 km/h range starts dropping off fast but
3 - Short trips hit range due to the need to heat the car / battery etc so longer trips are good.
4 - Driving at 100% battery prevents regen so hits range until you are below 95%
5 - Racing away / heavy right foot
I have done some very long drives at 60/65/70/75/80 mph and yes range drops off as you get faster BUT as the battery warms up through hot weather / fast driving the range seems to increase again. This allowed me to get the same range at 75mph in 40C crossing Spain after a few Rapids as at 60 mph on the 1st leg in France with cooler weather, 21C I think.
If you do a trip regularly, you will soon learn the percentage used each way & what speed & temperature. If your battery is dropping faster than you need you slow down, if you have plenty spare you can speed up a bit. I did 65mph on a long leg with unreliable chargers but 75/80mph when they were plentiful & ultra rapids. A cold battery will only charge at around 40-45 kwh but a hot one (on my MG5) charged at 92 kwh. The same will apply on any car battery, which is why Tesla pre-heat theirs when the destination is set as a supercharger to aid faster charging.
No easy answer other than you need to learn the changed parameters you work with compared to an ICE. EG - An ICE soon runs out of juice in a traffic jam whereas an EV doesn't, it can last a day or 2.
