fred12345
not on ZS.Do you have One Pedal Drive????
Try that if you do
Try that if you do
So far so good, not going for the gear stick quite so much and getting used to the regen thing, it’s just the stopping and starting on a steep hill that I’m nervous about lol, will having it in auto hold be enough!!
No, the zs doesn’t have that so I’m just trying to muster up the confidence that auto hold will do the job on a steep hill instead. Nobody seems to have replied saying otherwise so I’m guessing it will be okay.Do you have One Pedal Drive????
Try that if you do
Fully agree with Fred - do it somewhere quiet - today, Sunday, is probably best!try on flat ground, then on a slight slope and then on a steeper bit. exactly the same.
Hi Pam. Auto hold is amazing as others have said. It will hold you on a very steep hill in my experience. I use it all the time with few exceptions. Just bear in mind that when activated & when stationary at a junction or in heavy traffic, auto hold only keeps you stationary for 5 minutes. After that the parking break automatically is applied. This means of course you must re-engage Drive to move off. It's worth knowing that when auto hold is engaged your brake lights are on. In dark wet conditions this may dazzle other drivers behind.No, the zs doesn’t have that so I’m just trying to muster up the confidence that auto hold will do the job on a steep hill instead. Nobody seems to have replied saying otherwise so I’m guessing it will be okay.
