I have rolec and I have trouble since it's been installed back in December, so I won't recommend rolecjust bought MG ZS ev can you tell me what is the best home charger
You could always consider fitting a suitable Wi-Fi switching device, if you wanted to control the timed charging function of your car ?.I don't need anything fancy as we have a carport and I can just pop out and start charging after the off peak rates start at 10.00 pm. I bought the cheapest I could find in Australia and it was still $950! And that is without installation. There can't be more than $100 worth of components in it so someone is making a killing.
?????.Not a BP Pulse.
Had no end of trouble with mine and on charger no. 2. First charger just charged constantly, second one the scheduling facility doesn't work and I can't control it with the app. It seems to be a common problem. BP say it's the car, MG say the car is fully up to date. Plus BP customer service was appalling, until Motability, through whom I lease the car, stepped in to help. Now having to look into other ways of producing a timed charge, either by buying a lead from Ohme or getting someone to install a timer, as suggested by the engineer who replaced the original charger.?????.
I have a BP home charger that works on Mini and Honda for scheduled charging via Chargevision but my MG ZS will not do a delayed charge only an immediate charge. I don't need scheduled charging so will only bother the dealer at the first service to see what/if any updates may be necessary.Had no end of trouble with mine and on charger no. 2. First charger just charged constantly, second one the scheduling facility doesn't work and I can't control it with the app. It seems to be a common problem. BP say it's the car, MG say the car is fully up to date. Plus BP customer service was appalling, until Motability, through whom I lease the car, stepped in to help. Now having to look into other ways of producing a timed charge, either by buying a lead from Ohme or getting someone to install a timer, as suggested by the engineer who replaced the original charger.
