StackH
- Sep 20, 2022
- Location
- West Yorkshire
- Not an MG
I was all ready to place an order to have a Ohme Home Pro charger installed, primarily to be able to take advantage of the Octopus overnight tariff, when I found out that it doesn’t yet work with the MG API. The result would be a “dumb” charger that doesn’t know the current state of charge in the vehicle.
I emailed their tech support and got this reply:
“We don't have a API support for MG at the moment but you will still be able to charge your vehicle with the Ohme charger. You will need to set a schedule that specifies how much you would like to add. For example, if your car regularly has 30% charge left after use and you would like to achieve a 100% charge during your charge session, you should set your target percentage to 70% in your charge schedule.”
Is this a problem? All this EV stuff is new to me so not sure if I’m worrying over nothing, or if I need to choose a different charger?
