How does this particular hybrid system work?
Highway Code Rule 123;
"You MUST NOT leave a parked vehicle unattended with the engine running or leave a vehicle engine running unnecessarily while that vehicle is stationary on a public road. Generally, if the vehicle is stationary and is likely to remain so for more than a couple of minutes, you should apply the parking brake and switch off the engine to reduce emissions and noise pollution. However it is permissible to leave the engine running if the vehicle is stationary in traffic or for diagnosing faults."
Congratulations on quoting the guidance provided in the highway code, which I would point out is only relevant to public highways not private driveways
Regardless to Highway Code Rule 123; my car is going to be warm and safe to drive on the frosty mornings, not as you see a lot of driver's struggling to see through a small scraped peep hole!!!
Which means it is relevant to me and many others.
So maybe putting some relevance on it might have been helpful rather than just blind quoting the text. Maybe if you'd said 'many of us can't use this due to the highway code rule on leaving an engine running on public highways' would have been clearer and more descriptive to others.
Not sure if the MG3 Hybrid runs in the same way as the ZS Hybrid+ but this is something you might need to be aware of
I think we have all heard this before. I for one have covered 5,000km with no such issues.
The car will not move when it's running via the app unless you have the key with you. I tried this out, when the keys were in the house.
If you use the app remotely to warm the inside of the car on a frosty morning to 'defrost' the windscreen, where does the heat get generated?
As far as I know, you can't start the engine remotely, which is the main heat source for the car. I know you can heat the seats and the steering wheel, but that's electrically generated heat independent of the engine running.
When the cabin heater calls for heat the system automatically starts the engine. This is the reason for mpg dropping in the colder periods, as the engine runs more often to keep the cabin heater provided with hot water from the coolant system to heat the cabin. When using the app to pre heat the cabin, the engine will start, the doors all remain locked and the transmission is 'offline' so the car cannot move, or doors be opened until you go to the car with the key.
The engine does start remotely to warm the cabin but there's no option to warm up the steering wheel up.
It's also very illegal not defrosting your car properly and driving off.
I think I know what I will go with.
Agreed. I am wondering if rule 123 does apply. It is an environmental consideration, about engine idling. Does the heater run off the battery, or does it start the engine?
Rule 123 also links to Sec 98 about idling causing noise and Sec 107 about safety and security, of the Construction & Use Regs. Does the car stay locked?
If it stays locked and does not turn the engine on, then no rule or regulation has been broken.
I jsut dropped the car off, I was hoping they'd lend me the Cybersmart for a week, no such luck, same model as ours 525 miles on it same colour.
It's gone in for this.
Our analysis indicates that there is an issue with your vehicle's telematics box.
Please go to a local MG dealer to do a diagnosis.
Please bring the below information to the dealer:
Conduct the vehicle diagnosis, and check TBOX in a high priority,
Create a SNW ticket
If the TBOX is with error, then do a replacement of TBOX with SIPS, but DO NOT replace the hardware
