How to change MG ZS EV time now clocks gone back?
If you use DAB radio it changes automatically.
I have been using DAB radio but it hasn’t changed the time I’m afraid.
If you go into "setup" on the centre screen, then "time" you'll find all you need.
I have new Trophy Connect. The centre screen is the radio. Do you maybe have different model?
You just need auto time on in car setings
This advice sounds like it should work but I can’t find it! On the bottom of the main screen there are a row of icons for home, satnav, music then car. When I press car I cannot see ‘auto tune’ anywhere. Sorry! Am I in the wrong place?
@Maria we have a Trophy LR ( not connect ) and I had to reset the time clock manually myself last week.
As @N2STY has suggested, put the car into the READY state.
If you use your finger and swipe the screen on the infotainment screen to the left, it will reveal another menu screen with a number of sib menu's.
Go into settings and look for time of day / time settings.
Not the charging screen, just the basic time settings screen.
From here you can manually adjust the time of day.
My system was set up to correct the time automatically, but it did not update it.
A bit of manual adjustment required !.
Let us know if you find the menu okay ?.
I really appreciate your hep! I’m in the car now. I have swiped left from the main screen. I’ve gone into settings, user, vehicle and still can’t see time! I’m sorry to be such a dunce!!!
I’ve been through every icon on the menu after swiping left. The car time is still one hour ahead on the dash and in the infotainment screen and I’m using DAB radio. I’m at a loss!!???
Okay here we go !.
With the car in READY mode.
In the info unit, swipe two fingers to the left.
From the list, select “Settings”.
You will be presented with screen to change the “Background auto - switching” .
Now use two fingers and swipe “UP” from the bottom on the info screen.
As you are swiping up, you will see the “Time” section appear.
Slowly swipe “UP” until you see the date tab, then below this you will see the “TIME” tab.
Select this !.
Now you will be offered two rotary wheels that you can adjust the hours and the seconds.
Adjust these to the correct time of day and then press the “OKAY” button !.
Happy days, you are done !.
Just ran through it again in my car and it works just fine.
Press the “HOME” button under the info unit when you are done, then swipe back to the right if you need to get to the opening screen !.
Okay here we go !.
Select this !.
Thank you so much. Was perplexed by my new EV screen. Now have the right time on it.
Okay here we go !.
Select this !.
Thank you so much for this. Our car clock was wrong following clock change at Easter. Dealer could not help.Car Manual ,no clock headings. Email to MG, no reply as yet.
My car changes the time automatically, although not immediately. I set it to do so when I first bought it (November 22), and haven’t had to alter it since.
That will be a NO then !.
Had to reset mine manually myself on both Gen 1 and Gen 2 models.
My wife's Fiat 500 is the same, never auto updates itself.
There is a setting on the car that performs this function automatically. When my car arrived, it was on Chinese time (I presume), but setting it to GMT, it changes when necessary, when it’s been driven for a while on the day/s after.
