AussiePete
Since I started using Android Auto (via USB connection) I've noticed there is a heavy battery drain and the phone gets quite warm. After a bit of searching this looks like a common problem. I've recently installed an AA Wireless adapter and found the drain is even worse. The first screenshot below shows over 20% battery drain for 2 and a half hours use. So I did some been experimenting and found the drain seems to be location services running continuosly alongside Google maps.
However I have found that exiting AA on the infotainment unit (on the AA menu select Exit) and leaving AA running on your phone, can reduce the drain by more than 50% (see 2nd screen shot) but still allows you to use AA functions including voice control and navigation when you need too.
