Dino
When I plug in to charge the display shows current SOC and time to full charge, but this screen disappears after a few seconds.
Is there any way to keep that screen on while charging? Or viewing while in charge?
Searching the forum I’ve seen some suggestions to view it but not all work for the SR excite and no suggestions for keeping it on.
There’s no button on the driver door handle and clicking the lock button on the key fob when already locked sounds the alarm.
Does opening the boot work or does it stop the charge? I had an issue with the charge pin sticking when the boot was open so I’m a bit nervous about using this option.
I want to make sure I have completed the full balance charge and check the percentage while charging. I don’t have a display for my smart meter to see if it is pulling a small charge.
At the moment I just wait till my charger app shows it is no longer charging or guesstimate the percentage based on the kWh drawn, but I can never see the screen showing connected finished or connected not charging as I unlock and pull the cable out straight away to avoid the pin sticking.
