Bubs
- Feb 21, 2022
- Location
- Galway, Ireland.
- MG ZS EV
So I recently ran into the dreaded “HV Battery Shutoff - Vehicle Control System Fault” while trying to charge on a rapid charger. I pulled in and tried to start charging I got a bunch of error and it kept starting and stopping. I first put it down to a dodgy charger so I moved. The next one had the same issue but this one told me "Abnormal voltage detected" and it stopped.
I put this down to the rapid charger software update that was needed and that MG hadn't checked the software updates 4 weeks ago when it was in for a service.
The first time I called a recovery truck. He disconnected the 12V and left it for ten mins. Reconnected it and the car started up. I went straight out and bought a 10mm spanner (everyone should have this in the boot).
But worryingly I also got it yesterday on the 7KW charger in work. I noticed on the app that charging had stopped at 85%. That's odd I thought as you can only set it in steps of ten in the car. either 80% or 90%. So I assumed the charger had stopped. I went out and tried to restart it with the swipe card.
Much like with the rapid charger it kept making the initial connection and then stopping I tried a few times. When I sat in and tried to start the car I got the HV shut off error again and was stranded again. This time I had the handy 10mm to do the battery trick myself but this isn't a long term solution.
In both cases, I noticed a similar pattern and wondered if anyone else had seen this?
So the theory is that when the HV battery is off and the 12v tries to start the charger 4-5 times it uses up too much juice drops to 12.9v and the car gets into this mode.
- When I tried to start the charger I got an error and it stopped charging.
- I tried to start charging a few times (either on new chargers or the same charger).
- When the HV shut-off error appeared I noticed the 12v battery on the dash was showing 12.9v (that is normally at 14.4v).
