I created an AI with all the information on MG4
Hi Everyone,
Every time I had an issue with my MG4, I found myself spending more time searching through manuals than actually fixing the problem. That’s why I decided to train an AI, using all available MG4 manuals, to help with troubleshooting, maintenance, and programming. This AI can quickly provide answers and solutions, saving time and effort.
It can answer questions about:
  • Diagnosing issues
  • Disassembly and reassembly
  • Software adjustments
  • Problem-solving based on symptoms
The goal is to help each other without spending too much time searching through all the manuals.
To try it out, here is the link: MG4 Tech Assist
If you’re interested, let me know what you’d like it to help with. I'm open to all kinds of feedback, so feel free to share your thoughts and suggestions.
Edit: For the moment the chatbot is not well-trained on the MG4 XPower model. I'm working to train the model for Xpower.
If you're using the manuals from my drive depending on how hard it is you could add all languages and Possibly other models to create a MG master resource
yes I tried to add more languages but i discovered that if I train AI from the same manual in two or more languages he isn’t “happy”.
Mine is defaulting to Italian (I think) without even asking a question. Great idea by the way.
The Aussies will be here soon, that'll be another language🙄
Hey mate, we've been here all along.
Most of the time we do understand plain English, throw some Scottish variants in, then we may have trouble.
I don't think any manual is written in "Strine", so you should be OK.
For vibes response…
Addressing Tire Issues
  • Check tire pressure and adjust to the recommended levels.
  • Inspect the road force of the tires: If the road force is not within specifications, replacing the tires with properly balanced ones may solve the issue.
  • Flat spots on tires can develop due to long-term parking without movement, leading to increased vibrations.
That has to be a ‘close, but no cigar!’
Doesn’t identify that increasing tyre pressures can reduce the effect.
Pretty amazing, all the same… 👌👍
Can we have this as a sticky?
I'm very concerned about sticky clutter. So I've added an entry to the already pinned Tips Wiki. The title starts with AI, so it sorts to (at present) the second entry.
For technical reasons, the Wiki entry may disappear briefly. I'm trying to get the AI entry added properly.
In truth, it's probably quicker to use the search button with the term "trained" (without the quotes). At the moment, the AI post comes up as the first hit. If it later gets harder to find, you could add the term "manuals". Or set up a browser bookmark directly to the ChatGPT page.
Thanks Coulomb,
I've bookmarked it, seems the most functional way
Some reason the search for me doesn't work correctly, seems to bring up most posts that don't include the search term & only has 10 pages so older posts that I'm looking for don't show
First forum I've used thats like it
I found that if you register with ChatGPT, you then get the option to select a language.
I registered but couldn't find how to change the language once you've registered, so I just entered "Please answer in English from now on" which appears to have worked too.
Hi Everyone,
  • Diagnosing issues
Thanks for this, I use ChatGPT daily and have created multiple GPTs (AI models) which help me in all aspects of my life. Thanks for this. Very useful.
Just prompt it in English.
I thought he was joking (because there was too much technical jargon in the reply) but I've tried it and it does indeed come up in Italian. Not a problem. Thanks to OP for doing all the work.
Can't you just ask Chat GPT where it has gone? 🤷‍♀️
I asked if it was still available online, and it basically said 'I dunno' and to ask you lot on the forum.😁
"I'm unable to confirm the current availability of the MG4 Tech Assist chatbot. The developer mentioned on February 20, 2025, that the chatbot was not well-trained on the MG4 XPower model and was working on improvements. It's possible that the chatbot is undergoing updates or maintenance. For the latest information, I recommend checking the MG4 community forums or contacting the developer directly."
All this sounds very, very impressive.
And way, way beyond my capabilities.
I've read all these posts so far and haven't got a Scooby doo. What ya on about.
Think I'll just carry on in my own Caveman
way. It's worked nicely for me so far. 🙂👍
I'm with Salty on this one, a bit beyond me, I'll try and give it a go once I've worked out what's what??? I'll wait for the neighbours teenagers to come back off holiday.
Until then , the Luddites and myself will run around with pickaxe handles bemoaning the future death of the forum.
Still , well done and pretty impressive, I think? 🤪 🤪
    Votes: 1,069 77.7%
    Votes: 208 15.1%
    Votes: 99 7.2%
