Maybe the same as the other MG's? I don't think MG is going to reinvent the wheel and instead maybe reuse what they already have.Does anyone know the complete list of voice commands?
I also thought so but they also use the same shitty app as the MG4 so yeah..It's a completely different platform to the other MGs, as it's an IM car not an MG really, so it wouldn't surprise me if it's different too.
Is the connectivity OK or as bad as the ratings on play/app store suggest?Yes just been updated.View attachment 40948
I don’t know how it is with the IM’s but with the MG4 it’s far from perfect- The problem is that the car will enter a deep sleep mode (after leaving it for some time) in which you can’t pull information via the app and also can’t send instructions (like turn on AC..). I think the idea is to prevent the 12V battery from getting drained. The App for the MG4 is also very buggy and often displays no or deprecated information and so you have to pull manually again which is frustrating. Maybe they fixed it for the IM carsIs the connectivity OK or as bad as the ratings on play/app store suggest?
I have the exact same problems with my Citroen PHEV. I don't understand why these billion dollar companies can't get a basic app right.I don’t know how it is with the IM’s but with the MG4 it’s far from perfect- The problem is that the car will enter a deep sleep mode (after leaving it for some time) in which you can’t pull information via the app and also can’t send instructions (like turn on AC..). I think the idea is to prevent the 12v battery from getting drained. The App for the MG4 is also very buggy and often displays no or deprecated information and so you have to pull manually again which is frustrating. Maybe they fixed it for the IM cars![]()
How long is a ‘long time’? I’ve no problems with the app working with my IM, but it’s slowish and not very fluid as well as needing a face lift. But it works as it says on the tin.I don’t know how it is with the IM’s but with the MG4 it’s far from perfect- The problem is that the car will enter a deep sleep mode (after leaving it for some time) in which you can’t pull information via the app and also can’t send instructions (like turn on AC..). I think the idea is to prevent the 12V battery from getting drained. The App for the MG4 is also very buggy and often displays no or deprecated information and so you have to pull manually again which is frustrating. Maybe they fixed it for the IM cars![]()
Usually like 24-36 hours or if you leave the car over the weekend (at least in my case).How long is a ‘long time’? I’ve no problems with the app working with my IM, but it’s slowish and not very fluid as well as needing a face lift. But it works as it says on the tin.
So far so good, but I’ll let you know!How long is a ‘long time’? I’ve no problems with the app working with my IM, but it’s slowish and not very fluid as well as needing a face lift. But it works as it says on the tin.
The car apps all seem to use the cellular network to communicate. I think most, certainly MG, do this via some central server. So that's three points of potential failure, plus the car could be in a deep sleep.like the scan of the car - I even showed friends this - when the car was some 800 m away and from indoors. Not sure how it does that. Not Bluetooth?
I just leave everything at home now and only use the App. It's clunky, but I've been surprised how functional and reliable it's been for me given all the bad press it gets. I'd hoped that Zhiji being a JV between SIAC and Alibaba might have had a smoother App, but...Hmm, so far, quite happy with the app. The charging at home seems to work. I can open the car & drive away without using the fob. I like the scan of the car - I even showed friends this - when the car was some 800 m away and from indoors. Not sure how it does that. Not Bluetooth?
It's a shame there's only one fob but my wife can get the app & a digital key too .
The car uses the cellular network to connect to the central MG servers. The app connects to these servers over the internet.The car apps all seem to use the cellular network to communicate. I think most, certainly MG, do this via some central server. So that's three points of potential failure, plus the car could be in a deep sleep.
