Intermittent charging
mascott52
plymouth
ZS EV
I have a 2019 ZS EV suffering from intermittent charging. I think one of the pins in the charging port is broken off and not making contact with the cable properly. Anyone able to post a picture of their charge port so I can compare. TIA
One of the smaller pins it slightly set back.
Can you take a picture of your cable and socket on the car?
That's a design feature, to make sure if someone were to somehow be able to pull the plug out of the connector while charging, this pin would lose connection first, signaling to the charger to stop feeding power to the car. The CP pin is thus shorter by design (You probably know, just adding it for anyone else, that did not know)
Thanks that makes sense. But how much shorter. Mine is very short and looks like it would struggle to make a reliable connection
It's fine, it does as hmadsen says above and it also makes it impossible to daisychain charging leads (as the 2 cp leads will never make contact).
