MG ZS EV 2024 charging port door won't open (dead 12V)
What....So they need to sit and monitor the computer because otherwise it will time out ?
I was told this when I asked about the Tesla fix. A tech has to monitor the process. They even wanted me to pay for a second tech if I had it done at the 2 year service. I think you can probably guess my reply.
I would have imagines that it was like with a windows install, you start it and every 10 minutes you just press "Continue" and then it would do it, by itself and if you left it for 1 hour it would still happily continue after you pressed the button.
This method is so archaic, especially when other manufacturers have been able to update every bit of the car Over the air for longer than the ZS EV have been around. :)
You don't have to sit & monitor for the whole time. In fact MG are quite good from what my dealer tells me but all cars require monitoring with interaction at various stages during the process otherwise the car will stop & wait for the next instruction & will disconnect from the main central computer if not done within a fixed period of time.
I would not describe the current update service as archaic. It's one followed by every manufacturer. It's safe which is what manufacturers seek. I am not aware of any manufacturer who currently allows their cars to update critical systems over the air. Firstly it could take a long time due to bandwidth issues & secondly it's simply not reliable enough & can brick a car if anything goes wrong. Of course, our cars & others receive certain updates over the air but these are not critical updates. For example, my own car received new map updates over the air a few days ago. This occurred after doing a system hard re-set to try to cure the issues the car was having. Next day upon start up the map updates were waiting for me. It all worked rather well.
From my own experience in the trade it looks to me as though MG are much more advanced than many other motor manufacturer regarding EVs. And more advanced than many people give them credit for. Of course, they get issues like everyone & nothing is ever perfect. But by comparison to Peugeot & Citroen & particularly their EVs, MG are streets ahead. Much more reliable & largely trouble free by comparison.
UPDATE: my neighbour who has a Tesla tells me he thinks some critical updates are available for that car over the air as hmadsen indicates. He's a tech & like me was surprised by this.
I think the trouble is, that the UK Government won't allow over their updates of Chinese Car for security reasons.
Ok, just an update regarding the 12V battery & the ZS's ability to charge this battery.
I can now be completely clear on this. THE 12V BATTERY IS CHARGED on the later MG ZS EV's when the vehicle is parked & switched off. Not only has my dealer confirmed this, I have also checked the car owners manual which states very clearly (page 9) that the car will intelligently charge the 12V battery when the car is switched off.
I say to hmadsen, check your manual.
I have witnessed my car do this at least 4 times. My friend also with the same car has noticed his car do this too. There is no doubt about it. If someone's 12V battery hasn't been charged, you may have a fault which has caused the intelligent 12V charging to stop or fail to start, as per what the manual says.
I do not know if this applies to some earlier cars or if this is just the MK2 ZS LR TROPHY CONNECT EV's. Mine is a later 2024 model purchased January 2025. Although I'm running the very latest software for the BMS & every other module, my car still charged the 12V battery with its older software. So this isn't happening due to any upgrades the car has had. I do not know if there is an upgraded software to allow other cars to charge their 12V battery also. Hoping this helps others to be more certain about the situation.
FURTHER UPDATE: The MG EV forum Podcast covered this 12v battery charging issue last August where Miles from Chorley MG group stated that the most common cause of 12v batteries going flat is due to one or more of the cars 6 ECUs failing to go to sleep causing a considerable parasitic drain. This causes the cars intelligent 12v battery charging to fail/stop. This is to protect the main traction battery. Of course there are other things that can cause a parasitic drain too. If this happens more than once it's worth checking with your dealer for a software upgrade which will make sure the ECU's go to sleep.
We have a gen 1 MG ZS EV, there is a cable inside the bonnet to open the charging port if the electric lock fails.
It seems odd that MG would have deleted that cable.
Have a look on the right hand side of the engine bay for a cable.
Pete
I have a Elon-car and i can assure you it has received every single update OTA and even though they have had a few recalls they have all been done via the OTA procedure, my car is just over 2 years and it has yet to have its first visit to an Elon repairshop (Incidentally it is going to them in a week, but that's only to have a few warranty related issues fixed because if has just about run out of warranty covered miles :) )
ChatGPT (could be wrong) says that Tesla, Rivian, Lucid, Polestar, Volvo, GM (Selected vehicles), Ford Mustang, all Nio and all Xpeng cars, all have the ability to update every onboard module via OTA.
It seems that even the new MG S5 only has OTA for infotainment and telematics and we all know what that means...Atleast in regards to the ZS EV, that has it, but even though there has been numerous updates to the infotainment software, they never did it via OTA.
So in my opinion MG is not "ahead", not even in the Chinese market, from which Polestar, Volvo, Nio and Xpeng all originate.
Just to clarify....When there is a software update on my Elon car, it will automatically download it when connected to wifi (In my driveway) and when it has downloaded the update, it will prompt me that there is an update, in the app and i can then apply it now or schedule a time to do it.
If i select to start "now" it will say " Car will be undrivable for XX minutes while the update is performed" and i have to acknowledge that before it starts.
It typically takes between 30 and 50 minutes and i get another notification in the app, when its ready again.
I only do updates in my driveway, but i have never had an update fail me and i have received over 20 updates over the course of these 2 years.
Notable mentions about functions is, a year ago, they updated the headlamps to do matrix lights and just recently they activated a radar (That no one knew were there) in the headliner just behind the roof light, this radar is now able to detect if someone was left in the car, even able to "see" through the seats into the backseat. If it detects someone in the car (Forgotten child f.ex) it will send a message to the app and if the temperature gets above a certain setpoint it will automatically run the AC (I presume the same if temperature gets too low).
I'm not trying to knock the ZS EV, its a great car at the price we paid, but it is lacking and the fact they sold it as "Can be updated OTA" and then sent exactly 0 updates IS a bit poor in my mind.
That's very interesting hmadsen. I base my opinions about MG on a lot more than whether they get OTA critical updates. ChatGPT isn't quite right but clearly OTA is how it's going. Unlike you, I have had OTA updates. You clearly haven't needed them yet as yours was updated at the dealer before purchase. Mine car was not. Updates are not required that often. It's not a windows computer!! It's usual for dealers to check at service times for any updates for the car & automatically install them if available. My dealer does this. And do check your MG owners manual, it will charge your 12v battery when it's turned off!
Hi Data, I'm really interested to hear more about your OTA updates. I have a ZS LR (Portuguese), bought 3/24 and have received no OTA updates, despite trying.
Chris, it's not unusual to not get any updates. Your dealer should have updated your car before you took delivery. Most dealers do this as part of the pre-delivery inspection before you take delivery of your car. That means you are unlikely to get any further updates just yet. In fact it may be at your next service before you get any at your dealers. Always ask for an update check when it's in for service. All good dealers will do this anyway but ask also!
In my case my car somehow missed getting it's updates at pre-delivery inspection. My car had really quite old software. So I did get new maps software updates OTA. However, due to some warranty work that my car needed my car ended up getting completely new software. So I won't be expecting any further updates for quite some while. Probably not untill next service. Remember, these cars don't need updates like your Windows computer!
To be honest i would be just as worried about a certain US carmaker, if they fear nefarius actions, nowadays :)
MG does get over the air updates. But not critical system updates.
What MG are we talking about then ?
The ZS EV was sold as "Can update OTA" but to my knowledge no MG ZS EV has ever received any of these.
And, it's not because there have been no updates, it's just, they never did them OTA, but only at the service checks in their workshop.
So you have had a message pop up on your screen saying something to the effect of "There is an update for the infotainment available, do you wish to download and install" ?
The map updates was not advertised as part of the OTA, did you really get an update OTA.
Normal procedure for updating the maps, is downloading a file, unzipping it onto a USB drive and plugging that into the car, entering the menu to start the update and then it takes about 45 minutes to do the actual update.
Did it pop up on screen, saying there was a map update ?
Yes, I'm familiar with the usual map update procedure. I've already aided a friend to do this on his earlier car.
Yes, I did get an onscreen map update message when I started my car. To get it I clicked the 'ok' button. The system closed down & appeared to be installing files that it has already downloaded. I had to agree to the licence by clicking another ok button. But this whole thing to update took just a few mins or so. Afterwards the navigation system worked correctly & appears to be up to date. However, I remind you this happened after a system hard reset (as per my earlier post) the previous day. My dealer says he has heard of this happening after a hard reset but he wasn't sure if it would be the latest map file. I now have a suspicion that possibly what happened was a re-initialisation of the factory installed map & licence agreement. As yet I've not had an opportunity to delve deeper into this. At the moment I've got rather more pressing things to do. Also, there appeared to be another update that came in alongside the map stuff but that happened very quickly & was something to do with the cars main settings. That one is a total mystery at the moment. However, everything is working fine. I'll investigate further when I have time & report back.
There is another dimension to this. My car has been under observation by MG, & with my permission they have been monitoring the cars systems & performance along with location due to some warranty work they carried out. This has been to ensure everything is performing correctly. In fact they have only just stopped monitoring it as everything is now ok. They deleted all information collected about the car. I'm wondering if they may have updated some parts of the cars new software. Time will tell I guess, but it's all very interesting as far as I'm concerned.
By the way, both my dealer & MG have excelled in the way they solved my cars issues, all under warranty. Very helpful & no reason to complain.
Steady, last time you made such a solid statement like that you were completely wrong!! :ROFLMAO:
Seriously though, if you let me know what map version you are running I'll check mine & we can compare notes. Yours is a new car of nearly the same registration month as mine.
Mine was delivered in January 2025 and it had 2022 maps on it, after about 2 weeks i updated it to the latest 2023 maps myself using the USB drive method.
In those 14 days i did not receive any OTA updates for the map, and you are the first person i have ever heard, that had any OTA updates and updates to the maps were never a feature they advertised, which makes it even weirder.
Do you have your car connected to wifi at home, mine is not, so maybe it only downloads stuff via wifi (My Tesla only downloads maps and OTA updates via Wifi)
Hmm. I am suspecting that this wasn't over the air update, but rather a reinstall of software already in the car's computer.
