JonLovejoy
- Feb 22, 2022
- Bradford, England
- MG5
This looks like a maximum charge speed of 86kW (adding 10kWh in 7 minutes)? I saw the same on an MFG 150kW unit so this is likely the maximum the MG5 supports. Mine was on a warm October evening after 150+ miles so battery would have been at a good temperature.Pressed send before I'd finished! Stopped off at Baldock Services en route to Portsmouth (our France trip) and was really happy with the economy of the drive and subsequent charging speed.
The LR has a maximum speed of 100kW, I'm going to try running a little further between Ionity chargers in France to see if an even lower SOC will help me reach the grail ???This looks like a maximum charge speed of 86kW (adding 10kWh in 7 minutes)? I saw the same on an MFG 150kW unit so this is likely the maximum the MG5 supports. Mine was on a warm October evening after 150+ miles so battery would have been at a good temperature.
Edit: from below - it looks like (at least the MG5LR) can exceed 80kWh - which is nice ?The LR has a maximum speed of 100kW, I'm going to try running a little further between Ionity chargers in France to see if an even lower SOC will help me reach the grail ???
But as proven above it was doing more than the advertised 80kW. (in the photo 86kW at 45% SOC, quite impressive)No - it doesn’t I’m afraid. The Long Range and Standard Range both have identical quoted charging speeds of 80kWh
For marketing reasons (and perhaps availability of units), the Standard Range seemed to quote speeds on a 50kW unit whereas the figures for Long Range quoted a 100kW. But they both do 80kWh.
It is of course entirely possible that EV Database is wrong ?
Standard Range:
Long Range
Yep - I have a suspicion that the unit displays the power it draws, not the power it provides to the car so you're being charged for any losses in the process. 86kWh is a 7.5% loss (compared to 80kWh) to AC->DC conversion, heat, etc - which sounds plausible? Or maybe the 80kWh is an average figure and it can peak a little higher. But, both he SR and LR will charge at the same speeds of (approximately) 80kWh. I'm speculating a touch on this based on the quoted figures.But as proven above it was doing more than the advertised 80kW. (in the photo 86kW at 45% SOC, quite impressive)
I have also seen a James &Kate Youtube where he has mentioned charging speed of over 80kW on a 5.
Cool - good to know ?Confirmed by esteemed MG dealers I'm afraid, I did contact EV database about their error but they are yet to correct it. 92kW in France ??
Looks like over 90kW today ?But as proven above it was doing more than the advertised 80kW. (in the photo 86kW at 45% SOC, quite impressive)
