@Data - I really appreciate all your words of wisdom re. the scanner/apps etc., but I have sent it back to Amazon. It’s just too much of a faff! I gave up.
I bought a 71/2022 Mk2 ZS EV about a year ago. I have just installed the eZS app (great app!) and it tells me that the battery SoH is 85.4%. Is this normal for a 4-year-old car?
It doesn't appear anyone has answered your answer to the question of SoH for an X year-old car MG ZS EV, but there's a discussion on this forum - MG ZS EV MK2 - LFP (standard range) - Battery SOH Theory | MG ZS EV Forum - about the MG ZS linearly applying a SoH degradation percentage every single day.
I think that, with the LFP, the system has trouble working out what the real degradation is, so just arbitrarily applies a number until it learns otherwise.
I've got a 2022 Standard range (LFP), and that is reporting ~89% after being driven for three years. The distance doesn't seem to matter at all. The BMS just says "this is number".
The equalisation charge should help you, as people were reporting sudden jumps in their reported SoH from the OBD reporting apps.
I've not managed to do a proper equalisation charge, so my number is still going down, by the same amount, each damn day. If battery degradation is not linear, then I definitely shouldn't've lost this much by now.
According to random info across the internet, slow charging counts as anything between 0kw - 7kw, so if you ran it down to "low" battery, a 7kw would see the car charge be full and equalised in MUCH less time than the trickle charger supplied with the car.
I went from 0% displayed charge to 100% in 9 hours and 26 minutes, with the equalisation still happening. I had to stop it to leave unfortunately, but I know the car accepted ~48.5kw during that time.
The iSmart app wasn't reporting any charging speed, but the charger I was connected to definitely was!
Yes, SOH is dynamic. The SOH figure applies only at the time of checking & might be better or worse next time. Although generally it should not vary by large amounts. If a battery is equalised correctly on a regular basis the SOH will be quite stable & you retain a good range & state of health for much longer. SOH can also improve a little on cars that have not been equalised correctly over a period, or not been equalised at all if equalisation is carried out quite frequently for a period of time.
At what SOC is it best to measure SOH?
Just after a balance charge at 100% or after driving and a lower SOC?
It's generally accepted in the battery engineering world that checking SOH at 100% charge after an equalisation charge gives the ultimate SOH reading for obvious reasons. Doing it at lower SOC won't be as accurate. I tried this myself & obtained two different readings.
Curious, how much time did pass between the two readings and what was the actual difference?
Hello Mick, yes the time period between the two readings was 3 days. I recorded 100% SOH an hour after a full equalisation/balance charge in near freezing conditions. Three days later at 39% SOC & near freezing conditions my SOH was showing as 99.4%. Hardly any difference but as batteries age & cover more miles it seems this difference increases a bit. My dealer had checked my SOH 6 weeks earlier at a SOC of 66%. That SOH reading was 100% in near freezing conditions. A friend with a 3yr old long range ZS has 97% after a full equalisation charge & at around 45% gets a reading of 95.5%. His car has covered over 50,000 miles though. It was his readings that prompted me to check mine. I did this purely out of curiosity. I'm not concerned about battery SOH.
So, what does this tell us? SOH is dynamic. It is dependent to a degree on battery voltage. It is influenced by battery temperature. A lower reading one day may be higher the next. So a few variables appear to affect the figure. Does it matter? No.
EDIT: Just to mention that checking my own battery SOH once again a couple of weeks after all the above showed a reading of 100% SOH at 48% SOC.
The ambient temperature plays a big part on HV battery performance and its charging rate ability.
This is the reason why the battery can be brought up the ideal temperature prior to taking on a rapid charge, by the use of the battery heater provided.
Interesting, I always thought that while a battery’s capacity is dynamic the calculated SoH is steadily decreasing according to a degradation model (mainly based on age and no of charge cycles)?
Only when one recalibrates the BMS (measuring current capacity and comparing it with the ‘spec’) is the SoH corrected?
Your observations seem to suggest that MG is adjusting SoH based also on environmental factors unlike other manufacturers?
It's the same on our E-Niros & even the Leaf. It's also so very dependant on whether someone has balanced the battery at the point the SOH is checked. Since all car batteries are affected by the same variables I doubt MG are doing anything differently to other manufacturers.
