morf
Hi, When you open the iSmart app at the top left of the home screen you have the menu icon (3 parallel horizontal lines). When you select that you get the menu screen with 5 further options to choose. The second one down (under the "Remote Control" option) is labelled "Travel" which if selected goes to a map screen where you can search for a destination (eg a post code) which when found you can then select. Once selected it returns to the previous map screen with 2 new options at the bottom of the screen labelled "Create" and "Send". If you select "Send" then after a few moments a message pops up basically saying that the journey has been send successfully to the car.
Now the problem I have is that I cannot then find this destination anywhere in the Sat Nav on the infotainment screen (Trophy version only of course). No mention of a new destination having been set. I also tried the "Create" button which then also allows you to send it to the car (also get the same successfully sent message). Once again no sign of the destination having been sent to the Sat Nav.
Am I doing anything wrong, or this another non working function either in the iSmart software or perhaps the infotainment software? Has anyone managed to use this feature successfully?
