Thanks that's almost enough reason to change my order to an MG4 while waiting for the ZSIt does regen in adaptive cruse, the numbers go negative as a percentage, seems to max out at -17%
The power meter in ours definitely goes negative when using the brakes.Also can anyone confirm if this is correct:
The salesman told me that the MG4 doesn't have any regenerative braking when using the brakes ie has traditional brakes, not blended brakes
Im not sure to be honest. If I let off the accelerator completely in max regen, the power meter goes negative but if I then press the brakes, it goes much further negative than it does with no pedal inputs at all.It seems to be a setup like the model 3.... Come off the accelerator and you get full regen, brakes are then additional physical help but you don't get extra regen when brakes are applied.
This is unlike the Zoe where the first part of the regen is off the accelerator and the first part of the brake pedal is more regen, the brake calipers only but if you push harder on the brakes.
FWIW the tesla / MG4 way is my preferred way.
This is what happens in some other cars.That puzzles me - how can friction brakes increase regen? (Unless the brake switch coming on activates a regen+ mode?)
So it looks like @t3rminalV's observations are correct.IBS supports brake energy regeneration. When the brake
pedal is pressed for braking, the IBS will determine the
driver's demand for braking force. The drive motor will
convert the vehicle's kinetic energy into electrical energy,
which is stored in the high voltage battery when the vehicle
is decelerating. This process can improve the range of the
vehicle.
