Phil Hayward
Has anybody noticed a reduction in regenerative braking in cold weather, the battery might not accept full regen if cold?
Most of my trips are only a couple of miles or so .my batteries must be like ice cubes ha ha
I haven't got my MG5 yet either but glad to see its better. Have you got a ZS ev as well?I haven't got my MG5 yet but my wife's Zoe has noticeably reduced regen when either close to battery full or it is cold (and it tells you so on the screen).
FYI the regen effect on the MG5 is way better than the Zoe (which has two settings).
Yes I’ve noticed it too. I’ve done a 75 mile journey today with the heater on hottest setting although on number 1 fan speed and I only had 10 miles of range left - does having the heating on drain the battery that much that I only get 75 mile range despite the on board computer telling me I’m achieving 3.1 kw/h ?Has anybody noticed a reduction in regenerative braking in cold weather, the battery might not accept full regen if cold?
There was an issue with the BMS update and it sounds like your is one of those cars affected, Miles from MG Chorley has confirmed a corrected update will be out soon, hopefully next week.Yes I’ve noticed it too. I’ve done a 75 mile journey today with the heater on hottest setting although on number 1 fan speed and I only had 10 miles of range left - does having the heating on drain the battery that much that I only get 75 mile range despite the on board computer telling me I’m achieving 3.1 kw/h ?
Will this update resolve the poor range issue and the kers problem too and is it better to drive with the air con on or will it drain the battery in the same manner ?There was an issue with the BMS update and it sounds like your is one of those cars affected, Miles from MG Chorley has confirmed a corrected update will be out soon, hopefully next week.
It will help with the poor range in the cold; KER’s probably not and the air con I’m not sure as I tend to open the sun roof on tilt and the drivers window slightly..,however someone else maybe able to assist you with this question.Will this update resolve the poor range issue and the kers problem too and is it better to drive with the air con on or will it drain the battery in the same manner ?
