chrisc
Tyre pressures on my screen are in kpa how do I get it psi ???
One of the software updates changed it from BAR to KPA, so I'm guessing you don't have the latest installed.kpa?
Not bar?
Nobody has yet figured out how to change it from bar to psi. Strange you have it in kpa.
1 Bar is 14.5 psi. It's one standard atmosphere which is 14.7psi.100kpa = 1 Bar
1 Bar = 14.7psi
And what version have you got that shows kpa?One of the software updates changed it from BAR to KPA, so I'm guessing you don't have the latest installed.
Your correct it doesn'tAs I said earlier (and I'll recheck when I can) mine still reports Bar with 1100R33 ... the driver display is not linked to the Infotainment release version as far as I know.
Interesting. I can see in your profile you are in the uk. Did you change the settings? Do you mind sharing a screenshot?I have 1100R21 on my SE SR and it reports in kpa.
Thanks for the correction. I'd always thought that 1 Bar was 1 atmosphere but thinking it through 1 millibar would be 1000th of a bar and 1 atmosphere is 1013.25 mb (or hPa) hence the loss of 0.2psi.1 Bar is 14.5 psi. It's one standard atmosphere which is 14.7psi.
Rechecked today ... my car is still showing tyre pressures in Bar, even after the 1100R33 and other updates.As I said earlier (and I'll recheck when I can) mine still reports Bar with 1100R33 ... the driver display is not linked to the Infotainment release version as far as I know.
