Lane Keep Assist possible fix
Mine turns on/off at 60/55 :)
You got me intrigued so I did some more careful investigation. You are correct.
Most of our local suburban roads have 50 or 60kph speed limits however there is one close by spot with a higher one.
It did turn on at 62 but only after around 30 seconds of cruising at that speed. The section of road I tried this on is a 70kph zone where I would usually have got up to 70 by the time the 30 seconds was up and hence my "experience".
Once the car had "activated" LKA/ELK it then subsequently "instantaneously" turned on and off at the 60/55 levels.
Which still begs the question...
@grange What is this "different" behaviour that has made LKA work as you expect it should?
I can't see any difference other than an inability to turn ACC on/off via the "steering wheel" button.
Same here. What is the problem?
Just had my second service today and they did the LKA update. What a difference, instead of jerking the wheel out of my hands it now gently pulls it back in. (y)
I had become so accustomed to it jerking the wheel, that today, the first time it bleeped and started pulling the wheel, I jerked the wheel back and over corrected it. :LOL:
Just have it updated it will then work correctly.
    Votes: 1,064 77.7%
    Votes: 208 15.2%
    Votes: 99 7.2%
