Leaking pink fluid!
frostyqueen
Tasmania, Australia
Last night lots of pink fluid leaked from front left side after front end damage caused by bottoming out on a steep dip in driveway! Can I move the car? Drive 20 km to dealer?
It sounds like you have a coolant leak. Did you look at the fluid levels under the bonnet?
If it is coolant you can't drive it.
Pink fluid sounds like coolent, I would check the colant tanks under the bonnet, if it is coolent then I would not drive it.
