LED Bulbs
MG67
Denmark
Can I switch to an LED headlight bulb without having to replace the converter?
You can buy replacement lamps but they are of dubious legality.
Quite a few threads on this. Example:
I replaced the headlight bulbs in my Zoe 40 with LED, the lights were dire on it with halogen. The bulbs were a direct replacement, and brought the lights up the "acceptable". I never had any problem with MOTs or people flashing their lights at me.
2 things
1. Maybe rules are different in the UK, here it is not legal as the car was not approved to use LED bulbs, if the police stops you, they will fine you and you will be asked to do a MOT and the same, if the MOT station sees these, they will also fail you.
2. The big question regarding if it will work is more related to how the car actually feeds the bulbs. If its through a simple relay, it will probably work, but if not, it might fail as the LED draws significantly less power so the car might think the bulb is blown and cut the power. This can be remedied with a loading resistor to make the circuit use as much power as the halogen bulb.
If memory serves, i saw someone replacing some of the rear bulbs and they had to put in resistors to get it working.
I know people that have replaced their halogen with LED, it mostly gives off better light and no one is flashing them, but they do know, if they get stopped by some officer that is being really an*l they risk a fine.
PS. There is a ton of different LED bulbs out there, they are not all made equal, if you buy the cheaptest ali express bulbs they might not be very good
I joined this forum because of this actually, but if you search there is a lot of threads about it. Main take away: in some countries its illegal to retrofit led in halogen headlights, but most people report not having problems with MOT because they are not going to look unless there is a problem with the output (you are blinding people).
I had a Renault Megane with LED light before this car and its night and day, i cant see sh*t with the MG at night. I just ordered KOYOSO 9005/HB3 16000lm 60w led lights, they should be a direct replacement but with al lot more brightness. A lot of members reported using the 20000lm version from KOYOSO but its a little different formfactor, with a seperated module on a wire that sits between the headlights and the original connector. Oh and those lm and watts are per pair, so its 8000lm and 30w per light for mine. (If that 8000lm is true, might be marketing but they will be a lot brighter and whiter compared to the original halogens for sure)
