MikeJS
MYOB
IM6
This was published on the FB group by someone else and evidently provided by Miles Roberts from Chorley Group
Navigation
navigate to the world trade center
navigate to my company
direct me to the office
guide me back home
head to my place
navigate back to my residence
find a mcdonald’s nearby
locate the nearest walmart
locate coffee shops on the route
include a convenience store as a stop
change to the quickest route
change to the energy-efficient route
change to the most cost-efficient route
how long will it take to get there
when is the arrival time
start navigation
turn on the navigation
turn off the navigation
enlarge the map
adjust to a smaller map view
show me the map
start the route planner
shut down the map app
Phone
answer the call
pick up the phone
end the call
hang up the phone
finish the conversation
cut off the connection
let me check the call history
open the call records
let me see my contacts
show me the phonebook
display my saved numbers
end phone program
quit phone app
ring michael
place a call to olivia
Audio
start playing
begin playback
play now
play it
pause now
resume playing
continue
go back
play the previous one
play the next one
play in random order
switch to shuffle mode
play randomly
disable shuffle
stop shuffling
start the music
play music via bluetooth
play music from the usb
stop playing local music
stop playing music online
turn off bluetooth music
turn off usb music
pause the music
start the music again
play my favorite songs
start the radio
switch to the next station
add this radio station to my favorites
play my saved radio stations
switch to silent mode
mute phone calls
bring back the sound
turn the audio back on
adjust volume to five
change the volume to five
turn the volume down
set phone volume to five
turn up the volume
adjust media volume to its minimum
Seat Heater
switch on the seat heater
switch off the seat heater
raise the seat heating level(to max)
lower the seat temperature
reduce the seat heat by two levels
turn down the driver heat by two
adjust the seat heating to level three
turn the seat heater to level three
activate the seat ventilation system
turn off the seat ventilation
lower the ventilation setting by two
turn down the seat ventilation by two
adjust the seat ventilation to level three
activate the seat massage system
start the seat massage function
stop the seats massage operation
increase the massage power level
raise the massage intensity by two levels
increase the driver massage setting by two
lower the driver side massage strength
reduce the drivers massage strength by two
adjust the driver seat massage intensity to level three
set the massage intensity to its minimum level
turn on the wave massage for the seat
increase the height of the driver seat
reduce the height of the driver seat
Defrost
activate the defrost
switch on the defogger
Infotainment Screen
go back to home screen
return to the main menu
get back to home page
increase the screen brightness slightly
make the screen brighter
Windows
lower the window
put the window down
lower the drivers side window
lower the rear windows
activate the child lock
enable the left rear child lock
activate the left rear child lock
enable the right rear child lock
activate the right rear child lock
disable the child lock
set the child lock off
A/C
turn on the ac
start the air conditioning
turn off the ac
set ventilation to clear the windshield
start cooling mode
raise the temperature
set the temperature higher
raise the heat by two degrees
make it cooler
set the temperature lower
set the drivers temperature lower
adjust the temperature to twenty-six degrees
put the temperature at twenty-nine degrees
change the passengers temperature to fifteen degrees
set it to the lowest temperature(put)
turn up the fan speed
set the fan to a higher speed
raise the fan speed
raise the fan speed by two
reduce the fan speed
reduce the fan speed by five
put the fan at level five
switch to recirculation
deactivate recirculation
switch to eco mode
activate eco mode
switch to sport mode
activate sport mode
switch to comfort mode
I just tried changing driving modes by voice. It understands "Hello IM" and prompts what I'd like to do. Tried both 'activate' and 'switch to', none were recognized. It gives you three tries and gives up. I have a neutral USA accent, from CT originally. It did activate passenger seat vent, but not driver.
Had the car since early June '25 and never played with the IM voice control before, only Android Auto for calls and opening songs on Youtube Music etc. Anybody else had good luck with IM voice?
Car is in Thailand, language confirmed set to English.
I tried "switch to ECO" and it worked for me.
Open Android Auto doesn't though, considering it stars automatically only every 2nd time, I'd find it useful.
The list shared is non exhaustive so experiment and post any new commands you discover please.
For example, I've learned today that the car believes it's American. It does "open the trunk", but doesn't "open the boot"
I see. So if I should pinch my nose when I speak to make sure it understands....
Navigation
guide me back home
head to my place
start navigation
enlarge the map
show me the map
Phone
answer the call
pick up the phone
end the call
hang up the phone
end phone program
quit phone app
ring michael
Audio
start playing
begin playback
play now
play it
pause now
resume playing
continue
go back
play the next one
play randomly
disable shuffle
stop shuffling
start the music
turn off usb music
pause the music
start the radio
mute phone calls
turn up the volume
Seat Heater
Defrost
Infotainment Screen
Windows
lower the window
put the window down
A/C
turn on the ac
turn off the ac
start cooling mode
make it cooler
raise the fan speed
switch to eco mode
activate eco mode
activate sport mode
MG I want to see the sky
MG open sunroof
