LKA operation guide
I believe that is down to android and apple, they see it as a safety risk (software wise) or something. It’s been mentioned before on the forums but can’t fully recall what their reasoning was. It’s not a choice MG made though.
True. But software companies share roadmaps with their customers. And this one has most definite been on the map. So MG knew, probably even before they introduced R59. They had enough time to reprogram a button for allowing access to AC settings or LKA in AA mode. They did not.
Me too. If you wish to disable it in the dropdown menu and you use AA, this menu is no longer available unless you disable AA.
That's not actually "true". You just need to swap out to the main screen UI and the drop down menu works.
Then you swap back to AA.
I use this capability whenever I can be bothered turning off ELK, which really isn't that often.
You haven't disabled AA. You've just changed the focus of the display, and then change it back.
It's pretty simple.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
