PristDean
Totally agree, preferred driving mode should be retained. Also lane assist which does not work well in the UK unless you are on a motorway, should remain turned off if you choose.The main gripe is changing drive mode and regen mode ... unless you have a Trophy then these can only be done via the Infotainment screen - and the targets aren't that big. (OK if you do it before you start, but not so easy when you're already driving. If the car remembered your last settings then this likely wouldn't be a problem, but it doesn't - it always reverts to NORMAL drive mode and Regen level 3. Personally I prefer CUSTOM - everything Normal but Power set to ECO - and Adaptive regen).
