Made me smile.
Gadget Geek
Distinguished Member
Solutions
Somerset
I saw this, this morning and had to do a double take.
Yes, that's a white, Tesla Model 3 pulled up at a petrol pump!
(Didn't hang around to see what happened when he tried to put the nozzle in the charge socket :))
I've never heard of this before. Could you post a clearer photo of how you have your phone placed & secured please?
No problem.
The phone sits in a holder on the dash. It's 3D printed now, but my first prototype was made from some aluminium sheet.
The front panel stops reflected glare when the sun shines off it and the phone is held in place with some non slip matting.
I also added a HUD reflector on the windscreen so I can see the display in sunlight. The app also allows you to adjust the brightness and colour of the numbers so at night I have it display red digits at lowest brightness.
Wow, you've put some thought and effort into that!
It was after I got used to a HUD in my 28kWh Ioniq, and then the Kona version I upgraded to didn't have it. You don't have to go to all that trouble though;
You can just put a non-slip mat on an old CD case and use that. :)
Hi, I'm coming to this thread after a while. Hopefully you'll still be checking on this forum. 🙂. Have you still got your HUD working? I'm looking to add one to my MG4. All I really need is a speed display.
Thanks in advance.
Andrew
Thanks. Does it work OK just on the windshield, without a reflective patch thing? I'll certainly be giving it, or similar, a try.
Thanks
It does work on the windscreen except in bright sunlight, so the reflector is better. You could still make a reflector out of a CD case though.
