NickT
Hi we've had our MG 4 for just over a month now. Since the temperatures dipped below freezing our charge door will not close on its latch after charging. It will lock, so can hold it in and then lock the car. Then if unlock the car it will pop open. If noone is about to close it manually before driving off I have to drive with it open until it warms up, when the latch will then work again. I’m assuming this is cold related rather than mechanical failure as it does work later. Anyone else having this issue? Where we are in Scotland it will be below zero most nights through to March, so this will be annoying! I may buy a charger plug cover to see if this helps, if this is a fundamental design issue. Viewpoints would be appreciated, thanks!
