TaxiMan
come on guys, did you do this stupid sh*t with your petrol or diesel cars. What a lot of faffing around worrying about your battery. Just charge it every day if you have a home charger, (that is what it is for), its just a car, keep the tank full because its easy to do with a home charger and if there is ANY problem with the battery just pass it on to MG to fix.
I did not buy an EV to have to worry about the battery, as it is there is many other things that can go wrong but as it has a 7yr warranty I don't even worry about it one little bit. However in saying that my nearest MG Garage is 89 miles away so it is a pain in the backside to get them to look at anything. My heater blower has just started acting up in that when you try to go above 3 bars it just cuts out and initially I thought it was a fuse but no, when you turn the HVAC off and then back on it works perfectly until you try to above 3 bars again, so it is NOT a fuse but some other (probably software) problem. It is due its first service in Nov so I have asked them to look at the heater problem then.
Unless you are keeping the car long term past the warranty I would not even consider in any shape or form maintain some made up charging regime which is NOT even proven to be any benefit, all the inconvenience is just baffling to me, its a car and you probably will change it in 4 years, just enjoy it for what it is.
Regards
Frank
SPOT ON! Some folk take it to another level!
