Astrotom
I've tried to find something on this elsewhere in the forum, but without success.
I got a new MG HS PHEV back in March and it has been running with almost (the exception being gear change lag in EV mode at around 50 mph) no issues.
Yesterday it went to the dealers for it 6 weeks check and since then have had serious issues with charging (well not charging).
When I got home, I plugged it in to the wall charger and left it for a few hours. When I came back to, the battery was only about 80% charged.
I've since failed to get the car charging with the wall charger/cable combo. Everything shows as connected, status lights correct - just no charge being drawn. The estimated time remaining shows '17h 00m'. I've even driven to a public charge point to see if that worked, with no success.
I tried the granny charger briefly and that appeared to work. However, it only does so for five minutes or so at a time, and then stops drawing any charge..
Any ideas? I realise I'll likely have to phone the dealer on Monday, but would like to avoid handing over the car for an extended period!
Thanks!
Thanks!
