MG ZE EV Warning Lights
Maverick2017
London
Hi All,
Haven't posted for a while.
Yesterday when leaving work (car parked in covered car park), i had multiple warning lights & messages, see below
Forward Collision System Unavailable
Auto Emergency Braking System Unavailable
Stability Control Fault
Traction Control Fault
Autohold Fault
Hill Descent Control Fault
Hill Hold Unavailable
Tried restarting the car, which still had the same issue.
In the morning we had quite a severe downpour, with lots of standing water.
Fast forward to today, start the car this morning - Same problem
Got a mile down the road, just happened to glance at dashboard & all warning light & messages have cleared with standard message - No Faults
The only other thing that i had done was to turn on the Windscreen Demister.
I had spoken to my local WLMG service centre who suggested that this may have been caused by someone knocking the front & would require the radar being re-calibrated.
Has anyone else had a similar situation
Something similar, but the warnings cleared themselves. Try the 10mm spanner Alt-Ctrl-Del.
A lot of these faults come up when the camera in the mirror section is misted up. Check the air flow is fresh in not circulating in the car. They cleared because you turned on the demister
I often experience this, when starting close to trees/bushes and on an up-slope. I also suspect it has something to do with one of the forward-facing cameras or radar. In my case the Infotainment system often then restarts itself and the warnings are no longer there. In all cases the warnings are not persistent and are gone within a minute. Some posters warn to have the brake pedal firmly depressed when pressing Start and keeping it depressed until the car indicates Ready, making no other switch selections in that time. I do this but it does not avoid this particular symptom.
