Picked up mine 2-3 weeks into July. Seems like a batch arrived for July, initially ordered in Dec and initially due for March.
Has been great. First few weeks I did some tours around Ireland. Notched up 1500km. Three separate longish trips 300km, 410km, 470km. Only needed to charge on the last one as it had a good chunk of motorway and AC needed.
Last few weeks is in my normal trips. School run, work, shopping etc. Need to charge every 2-3 weeks. Which I can do in work for free so that's great.
The things I never knew it did.
You can play movies from a USB on the infotainment. Great if you are sitting in the car for a bit.
Quick access screen on infotainment by swiping down from the top. Let's you turn on Bluetooth, change brightness etc.
Bad things.
Rain (important in Ireland) comes in the window and drips on the electric window controls when driving. Also when you open the door a few drops will pool inside the door and drop in the seats.
Bluetooth turns on if your phone gets any message. Doesn't play just switches to Bluetooth. Annoying when listening to the radio.
Speed control (reads speed sign and slows you down) can only be turned on in settings. You end up not using it as I always forget to turn it on.
Good things:
Lovely to drive. Really fast, really comfortable.
Boot is a great size, fits buggy, loads of shopping etc without issue.
Goes forever on a charge.
