MG ZS EV SatNav deleting
For saved routes, Select new route, then select saved routes, select the route you want to delete, press the "^" in the bottom right corner and select delete (or remove).
For history, Select New route, then history, "^", then edit and press the little square with the two lines in it at the right hand side of the route you want to delete, then "delete".
Hope that helps. ;)
