MG ZS Steering Fault - clicking when turning
Hi there!
The procedure, made by me, solved the clicking problem for good! After 10.000Km done in different conditions and clicking is gone!
That's good to know! I may try this process later. I must admit that the clicking right now happens sometimes and at the moment they doesn't annoy me very much.
Also, as I say repeatedly, the steering column is hugely safety-critical and if there is any clicking noises AT ALL from there it should be investigated by the dealer - many columns have been replaced under warranty which is the only safe solution.
This is very wise advice, always get the problem checked out !.
It’s important to know if any of the parts like the lower universal joint has been compromised in any way.
In a lot of cases ( mine included ) the clicking noise ( in both models of the ZS EV we have owned ) is 100% coming from the upper section of the steering column assembly.
I know there is some owners who have had the complete steering column replaced under warranty.
But I can’t help wondering if this was diagnosed correctly 100% of the time TBH.
Why - Because if by increasing the torque value slightly of the manual adjustment nut on the upper clamp, does cure the clicking problem, then this has to point to this as being the problem area surely ?.
Increasing the torque value slightly is not going to rectify any internal issues that maybe present inside the column assembly.
But you are totally correct that the problem should be investigated thoroughly by a qualified professional.
Steering and brakes are the most important functions of the car and should be treated with respect !.
You are right! But before the procedures, I took the car at least two times to the dealer and in the report they just made "torque adjustments" and reported that the steering column had no problems... After the adjustments clicking sound from the upper clamp stopped for a couple of days, but returned even worse... So after a inspection made by a external mechanic to the steering column that confirmed the integrity... So only after that I made the procedure. Last Friday for precaution I took the car again to the external mechanic and afterwards for about two or three months everything is still ok.... I just made the procedure myself because I have no time to go over and over to the dealer waiting for a diagnosis that on those two occasions never reported a steering column falut... So if anyone that wants to use this procedure has to be aware of the risks, disadvantages, and advantages... Use it at your own risk!!!!
I notice most of the pictures on here show the pre-facelift model; I'm not sure my problem was exactly the same in my 2024 ZS EV Trophy. I had a clonk only when turning right, I haven't had the machine-gun type noises. Anyway, I took the car in to get it looked at (among other things) under warranty and they said it needed a replacement steering column. After several weeks waiting for the part it was finally done within a day a couple of weeks ago and happily the noise has now gone away.
Did you use Hendy MG in Poole by any chance Chris? (from Ringwood myself). Just picked up a 2023 ZS EV Trophy and it's got the same knocking. Hoping these guys know of the issue and it's a straight forward thing they can undertake.
Cheers
I’m using the 14 day return policy as leverage to get them to act on this urgently. Taking it in to the garage tomorrow (day after purchasing) to get looked at.
I've been to see the local MG technician and they confirmed the fault is as expected - upper steering column.
They confirmed that MG's repair process involves booking it in for an initial tightening of the appropriate bolts. Depending on the outcome of that, they then replace the entire upper steering column if needed (separate visit).
They did confirm it's a common fault, and one that they've seen before, and have confirmed the vehicle is safe to drive whilst the repairs are booked etc.
I'll keep mileage to a minimum in the meantime.
If they have 100% confirmed it is only the upper column assembly that is causing the clicking noise, then I don’t think you need to minimise your usage TBH.
They will attempt check tightening all of fasteners on the first appointment, then they may ask you to see how that goes, if the problem still persists, then they will likely raise a ticket with MG and ask for permission to order and then replace the upper column assemblies.
That’s good to hear. I appreciate it!
Cheers
Hi Jason - yes, it was Hendy MG in Poole (I'm in West Moors). They did replace the whole steering unit under warranty but it took a bit of persuasion for them to agree there was an issue. Mine made a distinctive clunk only when turning right.
I think you might have broken the camel's back there. They've taken mine in without as much as a "this is what people online are saying", and it's currently getting its upper steering column replaced under warrantee today.
Fingers crossed I can report good news later today when I collect it.
The steering column and steering wheel on my ZSEV has locked solidly 2 or 3 times. The first time this happened, after 30 minutes or so it spontaneously released itself and I drove the car home. The second time the same thing happened. On the third occasion I took it straight to the main dealer. It's been there a week and they say that they don't know what is causing this problem but they are communicating with the factory. Has this happened to anyone else??
I should read this thread and do not accept the car back until it has had the steering column replaced. I think you are extremely lucky that no accident occurred. I suspect one of the universal joints is faulty and became "bound".
How old is the car and were there any warning lights on the dashboard? Do you have the car from new or it's second hand?
The car is six years old or thereabouts but I have had it for seven months: there were no warning lights on the dashboard, neither was there any indication of what was about to happen. The main dealer has investigated and the car needs a new steering column but none are available in Australia so a steering column is on its way from China but it will take at least six weeks.
Has the garage kept the car?
It is not safe to use until the steering column has been replaced.
Thanks for your concern Tim. Yes the car is parked in the garage parking lot...six weeks is a long time but thankfully my wife has a car so we are still mobile. I am anticipating a large bill for the repairs and I'm trying not to think that actually, MG, this is your problem, not mine! Should stay positive!!
I think you should ‘assume’ it will be done under warranty. This is not a part that should fail in the lifetime of the car, you could argue the column is not fit for purpose and many have been replaced under warranty. Presumably the car is not 7 years old yet?
Good morning. I am happy to report that I picked my MGZS up from the dealer a couple of days ago and a new steering column has been fitted under warranty. The car was also serviced and the cost for this was AU$ 1075 which translates into 537 GB pounds...this did include one windscreen wiper. Is this normal??
