MG4 wheel swap efficiency hit tested
.... plus he has mud flaps fitted ?? ... I guess every little bit adds up
I wonder how you swap out the wheels and get accurate readings when full rotation is now PI*19 .....
He says in the video that the rolling diameter is exactly the same ? ... but wider wheels & tyres.
Regardless of the rolling circumference, there is a clear difference between 215 and 245, I also knew that when I was still driving a combustion engine ;-)
In this case, the new rims are heavy ones. But I'm thinking about what would happened if the new 19" rim were a "light" 9kg one like superliggera or Similar, and not a 12kg model like this. The change in the surface in contact with track would be higher but not the weight.
    Votes: 1,087 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
