Deleted member 11291
 - Dec 24, 2022
No chance with reel to reel or 8 tracks either then? Or am I really showing my age ?
			Thanks Macadoodle.I believe the x power just uses one of the standard perm mag motors on the front, no fancy decoupling mechanism in the reduction box.
If the motor is idle but still being spun by the cars forward motion, the magnets will still be causing electrons to flow in the field coils 'cogging' I believe is the term.
I have a few rc cars and aircraft with brushless perm mag motors and they all display this tendency if you spin the prop or wheels.
Wonder if this is the x powers' issue ? Good old MG cost cutting strikes again alas ?![]()
This is sort of what I’m thinking.I believe the x power just uses one of the standard perm mag motors on the front, no fancy decoupling mechanism in the reduction box.
Yes, I thought that when I was waffling earlier!If those losses are being generated anyway, why not use them as low level regen back into the battery?![]()
Surely when the front motor is being turned (when not in use) could be like a permanent re-gen?
If that's generating power I suppose the rear is working harder thus negating any benefit?
I've put on my energy consumption screen, I'm in normal mode (rear motor only) and when I'm decelerating I will see if both motors are used for re gen.
Just leaving Saundersfoot. Very nice ?
Thanks ChikyuThis vibration is also present in the Chinese version of the MG4 X-Pwoer. We have ruled out a problem with the front tires, and the vibrations can be easily felt on the steering wheel when traveling at 110km/h. Disappears below 100km/h.
My friend gave SAIC feedback half a year ago, but there was no progress or reply. The X-Power sold in the UK also has this problem, and I think maybe SAIC won't be able to solve it in a short time.Thanks Chikyu
I knew I had seen you comment somewhere before.
I take it nothing has been done about it by SAIC/MG where you are?
What's your evidence for this belief? Be good to have it confirmed one way or another if this is a design problem.I believe the x power just uses one of the standard perm mag motors on the front, no fancy decoupling mechanism in the reduction box.
I think Chikyu has with the Chinese version of Xpower. (or his friend)Has anyone with this issue replaced their tyres yet? Maybe to winter or all season or UHP?
Hi AndyI've noticed this too. I seem to spend a lot of time between 65 and 70 on my commute.
I'd describe is as sounding like you are overtaking a lorry.
You can feel it in the steering wheel as well as hear it, very low frequency and low volume.
As others have stated it happens in 4wd mode as well as 2wd mode, coasting, accelerating and regenning. To me, that means it seems unlikely that it's motor electrics related. I'd have expected it not to be present under hard acceleration in 4wd if it was a motor coupling / decoupling issue.... but I'm no motor expert.
My car is booked in on the 19th for someone to have a look at it.
AJP
Maybe they tested it and decided it wasn’t an issue. It’s just a characteristic.I think Chikyu has with the Chinese version of Xpower. (or his friend)
Double checking the wheel balance and a tyre change made no difference.
It's in amongst all the threads somewhere?
I am taking off my front and rear undertrays at the weekend,
The rear one is quite flexible (haven't checked the front but imagine its the same) and "could???" be oscillating in the air under the car?
Just to rule out another thing.
The more I dwell on it, the more frustrated I become. How was the car signed off by the test drive team?
Was there a test drive team?
Surely tens of 1000s of miles were completed test driving the car? and yet it's us, The G.B.P.T.D. "Great British Public Test Drivers" doing the bloody testing!!?
P.S. I still love my car.
Spoiler alert……..The vibe zone sounds more exciting than it actually is!!!
You see for me, it is there but not really an issue as I drive around it by taking A and B roads where possible ( I'm rural don't cha know??)Maybe they tested it and decided it wasn’t an issue. It’s just a characteristic.
Like ICE engines and their turbo lag or irregular idling or silly mixture for fuel economy etc…
I’m not denying it could be better and it’s probably quite annoying but I also know this is possibly what the budget allowed.
