G4GBP
Fordingbridge UK
MG5
MG5 (2024 model) 'System' menu?
I am trying to update my Sat Nav's maps. Car shows 22 Q3.
I have downloaded the latest maps from MG and put onto a USB stick (Maps folder).
The instructions to upload in the pdf say:
1. start the vehicle and put it in P gear. (OK)
2. Insert the USB drive in the USB port (OK)
3 Go to 'Settings>System>Tap on Map Update ??
How do I access the 'Settings>System' menu? I cannot find this option.
Thanks, Colin
Swipe across to the right of the main screen, select Settings and then System from the right hand side. Its not called Map Update on mine though - it comes up as Resource Update.
I seem to remember 2 things - there was some nonsense about deleting one of the files on the USB drive which you might have to google. The other thing I remember is that it took an absolute age to get started.
Did you have to do any messing about with files or did it just work?
No problems at all. I formatted the 32GB USB drive. Downloaded and unzipped the file. Copied the ‘maps’ folder to usb stick. 100,000+ files, took about 2 hours. Followed instructions, waited for car to load data, another hour. Worked perfectly. Very grateful for the help.
Same here. Last version was a complete nightmare, with my having to eventually delete one of the files before it would load, but this time it all worked seamlessly.
