Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
- MG ZS EV
Here is the latest 70,000 mile update from James on his MG5 work horse.
Not tried that, but I've found simply using the brakes, uses the brakesOn my previous PHEV (Ampera) the offside back brake bound and required a new disc and pads at about 40k miles, due to lack of use.
The recommendation with the car was to get up to speed and go onto (for instance) a long downhill motorway off ramp, knock it into "neutral" (to prevent KERS braking, which we can't do can we? - never tried it!!) and hard brake to the roundabout at the end, and do that at least once a month.
In the zs you can just put it in ACC...Not tried that, but I've found simply using the brakes, uses the brakes
Won't that be with the assistance of KERS though? Not a full-on pad-on-disc event...Not tried that, but I've found simply using the brakes, uses the brakes
If you put cruise control on at a low speed i think you can accelerate above it and friction brake back down to it. It does at least turn off kers when you aren't using the brake peddle.On my previous PHEV (Ampera) the offside back brake bound and required a new disc and pads at about 40k miles, due to lack of use.
I'll check at some point to see if the kers comes on as soon as no accelerator, with the brake peddle or not at all.Not so sure that's true, or am I misunderstanding? If I go above cruise control speed and take my foot off the Go pedal and don't touch the Stop pedal the car slows down, how quickly it does so depends on my KERS setting.
There is reference to using the hand brake in an emergency situation to slow the car down, in the manual for the ZS EV ( Gen2 ).On my previous PHEV (Ampera) the offside back brake bound and required a new disc and pads at about 40k miles, due to lack of use.
Not so sure it’s necessary, but I agree with your method as it would make sure it’s the physical brakes that is doing the work and not regenEasiest way to clean the brake pads is to charge to 100%.
Then give the brakes a rogering as there will be no regen produced.
Keyword there .. assistance, (and if not fully charged). Pad on disc is how brakes work I believe.Won't that be with the assistance of KERS though? Not a full-on pad-on-disc event...
I found it necessary to clean the pads as I disliked the squeal that happened reversing in the morning. I think some of it is no garage and a salty environment but if it didnt make a noise I'd probably have needed new pads at some point.Not so sure it’s necessary, but I agree with your method as it would make sure it’s the physical brakes that is doing the work and not regen
Les
I didn't opt for doing it sensibly. I just reverse while accelerating and braking together a few times till it stopped happening. My guess was that its the rear brakes which get applied with the hand brake causing trapped salt and water but don't get as much wear when out and about due to the regen and the way cars balance the front and back brakes. It could just be they some cars arrive new with slightly squint rear disks rather than corrosion as it doesn't seem to have come back now the pads are worn in.Hi aled salty environment I wished I had, but I did have squealing rear brakes on my 5SR almost every morning when reversing off my driveway, and the dealer had 4/5 attempts to cure it without much success, now the funny thing is a neighbour of mine 3 doors away got he’s MG 5 a week after me and has never every had any brake squeal, he’s still got his but mines gone have the the 5 trophy now but I hesitate to say minus the squeals, but I did hear it once one morning the first week I had it.
Les
