MG5 FULL SIZE SPARE WHEEL
Hi
I’m not sure what model Audi it was
But I have now used one of the spare alloys that I have after my alloy swop as a few people have commented on if I was in an accident with a Audi wheel on what would the insurance say
Anyway the way I look for wheels is the wheel size pcd and offset
Mg5
Wheel size 16” x 6.5”
pcd is 5x112
offset is 41mm
Hope this helps
How much did the entire wheel cost please Ian? I want to get one myself.
Hi
I picked it up off eBay for £30 + £10 p&p
There where plenty on there but this one had a practically a new tyre on it???
I still have the rim if you want it for free
Just private message me for my address
Ian
Hi
Ian
Did you still have a rim available Ian, one of the MG OEM, of that set of four that you had?
Hi
Unfortunately no
The last one is sold just awaiting on payment so I can ship it out
One is my spare and the other 2 were sold and picked up yesterday yesterday
Sorry
Ian
Hi
Unfortunately no
Sorry
Ian
No worries mate. Thanks anyway.
What is really annoying is they are called "spacesaver" because...... they save space.
Looking under the back of the car there is so much available space there was never any need for a spacesaver as there is more than enough room for the spare wheel well to be full depth.
Hi all
Just received my full size spare wheel (from an Audi)
The tyre is a 205/50/16
The wheel is a 6.5” x 16”
It fits in the boot spot on with the boot floor lifted to top position
(Mg5 LR)
Cheers
???????View attachment 6357View attachment 6358View attachment 6359
I'd love to get a full size spare for my MG5, which particular Audi model has this same size rim and is stock tire the same as mgs. Will look on eBay and check local breakers yard. Cheers, Harreson
Alloy wheels tend to be lighter than the equivalent steel wheel although probably less so with the space saver
I've got the official space saver wheel and kit here and it doesn't weight as much as I thought it would to be honest.
Hi I have a Seat Toledo spare wheel will that fit on the MG5 LR by the sounds of it it will? Please advise. Thanks
Could someone tell me if my Seat 16inch spare will fit the MG5LR and if I need a new wrench/Jack etc and also if the nuts will work on the spare if used? Thanks cery much
Hi
You will need studs that are for the seat wheel
As for the wrench the studs on the mg5 are 17mm so just depends on the size of the studs on seat
The jack you may have to try to see wether it fits on to the jacking points ok and wether it will lift high enough and don’t forget about what weight it will lift
As for the wheel it just needs to be popped on to see if there is enough room so it’s not catch the brake caliper (the front caliper is larger than the rear) or touch the inner wing when the steering is turned from lock to lock
Also don’t forget about the load rating of the tyre
Hope this helps
Hi Thanks for your reply.
Silly question are the stud shaft size the same for the MG and Seat/VW so I just need a set of studs (assuming the wheel fits) I have noticed the Seat spare is 15 inch with a 185/65 r15 tyre so I guess it may be too small for the caliper. Advice again please> thanks for your help.
I bought a VW Golf MK5 spare for my MG5. I did get some bolts to fit it as the profile is slightly different.
Can anyone confirm the new facelift MG5 still has an option for spare wheel? That is one of the things i like about it as i believe the MG4 does not have such an option.
I have a full size spare wheel from my ex pre-facelift MG5 going spare (for sale) if anyone is interested.
