MG5 scheduled charging
bisdains
Wigan
Not an MG
Hi all
Haves tried Googling and searching the dirum
But can’t quite figure this out. So far as I can tell
The MG5 cannot schedule it’s own charges and some have had issues with the charger scheduling charges?
Is it now possible to use a charger that can schedule itself without issue? About to buy an MG5 excite pre reg but not sure if this is an issue I need to be concerned about?
Thanks
No, not for me. I think there are some chargers that can’t wake up the MG but I’ve not seen that issue with the Zappi.
Works with Hypervolt too.
One thing I did find out was to make sure you don't plug the car in any more than 12 hours prior to the scheduled charge as the handshake process times out.
I have a new custom made EVSE (replacing a broken Polar) in which I had a SONOFF mini installed to manage turning it on and off remotely (mainly from my Home Automation machine). So when I plugged the cable into the car it had no power to it. The issue with that car was that the car horn beeped once or twice to indicate it was connected, so it'd do that when the power came on - usually in the middle of the night (cheap Octopus Agile rate).
I'm hoping it'll work OK with the MG5 when I get it though.
My Ohme works great easy to use app and links into the Octopus Go 5p tariff?
I leave mine plugged into a granny charger on a timer and over several days it will top up the car in the 4 hours Octopus Go window.
I think the handshake issue was fixed in a previous update.
My Ohme ...
Blummin OHME - I was going to order the OHME cable before I left for Portugal in late Sept. Forgot about it till the other day ( - I'm still in Portugal!!), and it's gone up by £100 to £299.
Doesn't really matter with the Home Assistant I suppose.
Good to know.
I have a wallbox plus, with an Octopus Go Faster 5 hour window. The timer works well.
I just have my Ohme set to charge when electricity is to per kWh do automatically charges between 12.30am and 4.30am.
You can also set a charge schedule on the Ohme app if you want to charge at specific times or you can use it as a dumb charger.
I have rolec wallow home charger. Not smart. I’m concerned that mgS5 doesn’t enable schedule for charging. How am I supposed to come out after midnight to plug it in??? Or am I missing something ? Cheers. On train to collect car now :-)
You could fit something like a Shelly to the CP wire in the Rolec EVSE
I would be very surprised if MG did away with a charging schedule/limit feature on their latest model?
This is taken from the manual for the MGS5 available on line to view/download here at https://www.mg.co.uk/owner-manuals (keep clicking the right arrow to to get to the MGS5.
On all for mg s5 EV I can schedule charging.
All good but domestic battery/inverter ( with free electricity from solar) can only send 3.6kw and then pulls the rest from grid. Expensive.
What EVSE do you have as on the Zappi you can set to only use 100% solar.
